What does everyone use to clean the exterior of their boat. Mine has water spots and I'm not sure what to use to remove them.
Cleaning exterior
X2Originally posted by MTtigekid View Postbabes boat bright and water spot remover!!
When my Bucket 'O Babe's is empty I'll order the Hot Sauce and determine which I like better but I am very pleased with Babe's so far.2009 RZ2, PCM 343, MLA Surf Ballast, Premium Sound.
If really bad you can use 3M Marine Cleaner/Wax either by hand or with a light buffer. I've used at end of Season before putting up and really works well. I used on my old boat that was oxidized by previous owner and it really did a good job.
This year I've been wiping down boat with the Babe's Spot remover on the lift after each outing and have totally kept the water spots in check.
Supreme Tigé Master- Sep 2005
- 9278
- 2005 24v
Uou can add a cap full of wax to it and it works great.Originally posted by Domsz06 View Postor can't believe no one has said this, just use the white vinegar and water mixture, 50/50 or is it applecider vinegar... I forget but it's a good one too..
Smells like crap tho....
Now I use hot sauce and cut it 50/50 with distilled water. Works just as good at 100% hot sauce.Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
Tigé Jedi- Feb 2004
- 5529
- St. George, Utah
Good thought! The stuff costs as much as gold if you break it down by the ounce.Originally posted by G-MONEY View PostUou can add a cap full of wax to it and it works great.
When I had some really severe spots...Lime-Away!!!!!! Worked even better than Flitz.
I think the Hot Sauce is better than Babe's I have been using for years. But I need a few more weeks with the Hot Sauce to know for sure.Be excellent to one another.
X2 for cutting w/50% distilled water. Order by the gallon or 5 gallon bucket to save some bucks as well.Originally posted by G-MONEY View PostUou can add a cap full of wax to it and it works great.
Now I use hot sauce and cut it 50/50 with distilled water. Works just as good at 100% hot sauce.2009 RZ2, PCM 343, MLA Surf Ballast, Premium Sound.
