I asked the same question they " said " sitting at the right angle will cause it to lose prime
2010 Pro Ballast RZ2, Front System Issue
So how did you lay yours over? What did you do?
Now that I can get in there and undo the pump, let water flow in, then put it back, I can reprime, so I won't be stuck again, but would like to not have to do that often. Thinking maybe close the check valves before putting up on lift to hold some water in? Less to prime?
Looking at the pumps, why would the front pumps be more likely to lose prime?
Thanks again, our front left wouldn't prime yesterday, we got in there and reprimed, and it worked.http://wake9.com/
Then your new problem would be frequent auto-siphoning. It is hard (if not impossible) to get the vent riser loop high enough to not siphon (even running on engine side of compartment).Originally posted by chpthril View PostBaring a kinked hose, I may look at removing the check valve and adding a vented loop up near the sac.
If you do go riser loop, consider running the vent line to the opposite side! Siphon solved.
Thats what the vented-loop is for, stop the siphoning, same as a check-valve.Originally posted by Duncan View PostThen your new problem would be frequent auto-siphoning. It is hard (if not impossible) to get the vent riser loop high enough to not siphon (even running on engine side of compartment).
If you do go riser loop, consider running the vent line to the opposite side! Siphon solved.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Only problem is, the new Tiges use individual pickup, so one would have to add on an elbow to each thru-hull to lay the pump over and get it lower in the bilge. Hard to say if there would be room.Originally posted by rushin View PostI rebuilt the manifold that all 4 fill pumps are in.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I don't know if this helps, but my boat has four thru-hull pickups also. It has these anti-siphon valves and I've never had a pump lose prime.Originally posted by chpthril View PostOnly problem is, the new Tiges use individual pickup, so one would have to add on an elbow to each thru-hull to lay the pump over and get it lower in the bilge. Hard to say if there would be room.
http://www.bakesonline.com/detail.aspx?ID=994
That's what i'm suggesting needs to be put in place of the bronze check-valves. I think the c/v's are holding water between them and the sac, as they are intended to, and the weight of the water is holding the c/v door closed and not allowing the air to bleed out of the pump. XPJim had this issue on his ballast install and removed/relocated the c/v's and bingo!. The vented loops work great and are found on a lot of boats with low freeboard. I try to avoid them due to cost, but sometimes they are needed.Originally posted by thtrog View PostI don't know if this helps, but my boat has four thru-hull pickups also. It has these anti-siphon valves and I've never had a pump lose prime.
http://www.bakesonline.com/detail.aspx?ID=994Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
