so I know there's been some of you on here expressing concern and wanting a different throttle. But the limiting factor has always been the Taps button on the throttle assembly. Well possibly no more.
Now be it, this is probably a very expensive option, but I see no reason it's not a viable solution.
http://www.livorsi.com/catalog/wheels.htm
Scroll down to the "Trim in wheel", which is second from the bottom. You wire in a radio reciever into our bennet trim tab, and mount it in the back. Yes there seems to be an application for the Bennet Tabs. Then mount this steering wheel and a new bling bling throttle, and voila!!!! What you guys think?
I agree there is some slight fading on the knob after some use, but I can't really see that when my hand is covering it up
