Tige 2004 20v Switch Taps Extending Far Enough?
    I had to replace my Taps actuator. I think I got the correct part but would like confirmation one way or the other. I could not operate the old actuator at all because it completely died so I have no comparison by which to judge if the fully extended plate is in the correct position with this new actuator, or if it should go down further or not as far. Can you tell from these pictures if the plate is extending the correct amount. The pictures show the plate in both end point, fully extended & fully retracted.
    In my experience, the Lenco actuator used in that era of Tige are either 2” or 1.25” stroke. Your original is likely 2”
      The replacement one I have on there now is 2.25"
