Tige 2004 20v Switch Taps Actuator
    Does anybody know if this is the correct actuator for the Taps plate on a Tige 2004 20v Switch? It has a 2.25" stroke and rated up to 500lbs. My old actuator does not work anymore so I cannot extend it to see if it was 2.25", but I think it was because the number stamped on it is 101LB092 which I think 101 means it was a 2.25" stroke. The casing is an exact sizing match. I dry tested it last night and the taps gauge will not go all the way to 1 when extended, at first it went to 3 even when the actuator was fully extended and then went to 7 before it was fully retracted, like the calibration was off on the gauge. Then for some reason it started going to 2, so maybe that mysterious black box is doing some auto calibrating.
    Amazon.com: LENCO MARINE 15054-001 Actuator 101 Standard,White,Medium : Sports & Outdoors
