Wire hot to the touch
    I was tracing down a wiring issue on my 2017 Z1 with my fuel pump and noticed this connector gets very hot after starting the boat. After only a few minutes it gets almost too hot to touch. You can see the discoloration of the wire in question. Anyone know if this is normal? The wire just comes off the main harness then into the fuse block looking thing and back out to a Y split wire to the fuel pump connector.
