Tige Touch with Aftermarket Surf System
    2012 Tige RZR - I added an aftermarket surf system with the M2 surf controller. The M2 system operates as it should. The one thing I can’t figure out is now the Tige touch screen will not respond as it should after a few minutes of being up and running. When pressing the touch screen all the top buttons go to the ballast system window and all the bottom buttons go to the video window. If I shut down and restart the buttons work initially but again after a few minutes it starts to act up again. When the key is turned to the left (accessory position) this doesn’t seem to be an issue. The pictures show where I have wired the controller. Any ideas what could be causing this?
