Why does my Dodge Charger feel like pulling to the right even after an alignment?
    I'm really frustrated and I'm hoping someone here has dealt with this before because my regular mechanic is out of ideas. I drive a 2015 Dodge Charger R/T that I bought used about a year ago, and overall I love the car. But for the past few months, I've noticed that on straight roads, the car wants to drift to the right. It's not super aggressive, but I definitely have to hold the steering wheel slightly to the left to keep going straight. If I let go of the wheel, within a few seconds I'm heading toward the shoulder. I took it to a shop and paid for a full four wheel alignment. The printout they gave me showed everything was within spec after they adjusted it. I drove out of the shop and the problem was still there, exactly the same as before. I went back and they checked the alignment again and said it was still perfect, so the problem must be something else. They suggested maybe a tire issue, so I had my tires rotated and balanced. Still the same pulling. I even swapped the front tires left to right to see if the pull would change direction, and it still pulls to the right. A friend of mine who knows more about cars than I do said it could be a brake caliper that's sticking slightly, or maybe a worn suspension bushing that's causing the geometry to change when the car is moving. I live in Sharjah and I've been looking for a shop that really understands Dodge vehicles because I want someone who has seen this issue before. I found a place online and decided to check out 800sayara.com/dodge-repair-sharjah to see what they offer. Has anyone else had a persistent pull to one side that didn't fix with alignment? What ended up being the actual problem? Was it a bad tire, a sticking brake, or something with the steering rack? I really need to solve this because it's making long drives very tiring. Thanks for any help.
