I went in for a routine oil change two weeks ago and somehow walked out with a whole education about things I had been doing wrong with my car for years. The mechanic took one look at my battery and asked me how long I had been parking outside in direct sunlight every single day and when I said pretty much always since I moved here he just shook his head slowly like he had seen this story a hundred times before. He told me the battery was showing signs of heat damage and that it was probably not going to last much longer even though I had only replaced it about eighteen months ago. That felt frustrating to hear because I genuinely thought I was doing everything right. I was not leaving the lights on, I was not making super short trips all the time, I thought I was fine. But apparently there is a lot more to keeping a battery healthy in this climate than just avoiding obvious mistakes. After that conversation I started looking into car battery care tips UAE drivers actually need to follow because I realized the advice you find for general audiences does not always apply when you are dealing with summers that push past forty five degrees for months at a time. Some of the things I read about were pretty straightforward once someone explained the reasoning behind them like why you should try to park in shade or a covered garage whenever possible, why you should check the water level in non-sealed batteries every few months, and why letting the car sit unused for more than a week without running it can slowly drain the charge in ways that add up over time. I also did not realize that corrosion on the battery terminals is actually more common here because of the dust and humidity combination and that cleaning them occasionally can genuinely extend how long the battery performs well. It is the kind of practical knowledge that should honestly come with the car manual but somehow never does.
My mechanic said I've been killing my battery without knowing it
