I have a 2005 22V with a tige tower and the thread on the bolts are getting wore down. Does anyone know where I can buy new tower bolts?
Bolts for tower
Which bolts? I just solved this similar issue a couple weeks ago.Originally posted by mkuiper View PostI have a 2005 22V with a tige tower and the thread on the bolts are getting wore down. Does anyone know where I can buy new tower bolts?
http://www.tigeowners.com/forum/show...ht=tower+boltsMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
A fastener supply place should have the stainless steel hardware you need. For the joint above the windshield, you need a 1.75 x 3/8 x 16 NCT and for the uprights, you need 1 x 3/8 x 16 NCT stainless steel allen headed bolts. You will need a washer for under each bolt over the windshield, and they will probably need to be ground down to reduce their diameter in order to fit in the hole.Originally posted by mkuiper View PostI need both bolts. Where the tower hinges and where the tower support goes. THe threads are getting worn down. So do you just have someone machine you new bolts then?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Are these the ratcheting bolts? I have a set from my oldOriginally posted by mkuiper View PostI have a 2005 22V with a tige tower and the thread on the bolts are getting wore down. Does anyone know where I can buy new tower bolts?
E series tower.
PM me if still need and which ones you need.I have for front pivot and the vertical billet
Ok, I know where the short ones go, and a bushing could be fab'd and slid over a std bolt. But I cant picture where the long one with he shoulder goesOriginally posted by mkuiper View PostI went by a bolt supply place and those bolt you told me to get are not going to work. Is there any way I can get the bolts from tige or a dealer? Attached is a pic of the bolts i need.
could you post a pic where it goes, that may help me come up with some idea.
Sent PM's to chpthril and mkupier re: bolts.
Originally posted by chpthril View PostOk, I know where the short ones go, and a bushing could be fab'd and slid over a std bolt. But I cant picture where the long one with he shoulder goes
Can you post a pic of where the missing bolt goes as well as a pic of the whole tower? This will really help up to help you.Originally posted by blakewake View PostI've contacted Tige about the long bolt that is needed for the joint close to the fiberglass. I have no bolt there. Any idea where to get one?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
