.Engine and TT display work, bilge blower, radio, lights do not
    11 RZ2. I had a problem where the subwoofer was getting static. Turned out the battery switch in the rear was causing a grounding issue that made its way to the audio. I sprayed electrical cleaner / lubricant on the switch and turned the switch back and forth to work it in. However i created a new problem - I mistakenly forgot the key was on when doing so. Now the engine starts and the Tige Touch display lights up to show the user interface, but the buttons will not run the blower, bilge, radio or lights. I checked the fuses and they are fine. There is also the manual switch bank under the helm but none of the breakers are tripped so there is nothing to push back in. However, all these manual switches seems to overlap with the items not working. I looked under the battery switch but don't see any inline fuses. Can anyone point me in the right direction. Cheers
    Figured out my issue. For others that run across this problem.
    My BUS breaker just above the batteries had tripped.
    It looks like one of these surface mounted ones.
    https://www.bluesea.com/resources/61...Breakers_Video
    My little lever was black and the red button was covered in black mold making it hard to figure out what it was
    Pushed the lever back in and found out everything was fine - and also that I hadnt really figured out the subwoofer static :-/
