So new to me 2022 Rzx and the starboard ballast pumps aren’t working. The pumps do work after plugging them into the port pump connectors but I don’t have power at the connectors for the pumps. I test drove the boat and spent two hours on the boat and after a 9 hour ride home the pumps won’t turn on. Where do I start? I e read the grounding bar on the back of the boat and if so where’s that at?
2022 22rzx starboard ballast pumps
Maybe this helps, Pg 173 of the PDF manual
https://www.tigeowners.com/downloads...ige_OM_WEB.pdf
According to this, in 2021 it was usually mounted around the starboard side transom wall.
Did you check the specific pump fuses? Fuse panel is in the storage ares under the port side (spotter seat)
If you run in dirty water and suck something into the pump, it will blow the fuse and you need to clear it or youll keep burning through fuses
