This post is more just to get the numbers out there if anyone in the future is looking for the same info for a 2000 2100V. I’ve had a really hard time with Bennett Marine trying to replace my actuators and find the right sensor.
I contacted Tige and they provided me with the following-
The Bennett Marine actuators used during the 2000 model year for the 21v model Tige were provided in the #198 Bennett Marine Tige taps kit and they should be able to assist you.
I sent an email to Bennett with no reply so I called this morning and was given the following numbers to search for, on my own. I was a bit surprised that they were unable to source the parts or direct me any further. It was more, here are the numbers, they don’t translate to anything Bennett Marine has, good luck.
I find it pretty hard to believe that there are “no” current BM sensors that would get the job done. Even describing the sensors to them “would be a guess at best”.
TIG4027STP
which if googled returns only one post from this site. But does lead to another number-
TIG198-218-238-A1525
Which does seem to go hand-in-hand with the Yamaha part number they gave me-
6BT-50065-32-00
I ordered this part today so we will see what happens.
there is another post “Taps 1 gauge sending unit” that’s states ATPSEN1.225SD is the new replacement sensor but I have yet to confirm this and the sensor itself looks different than mine.
Hopefully this saves someone the same headache.
TIG4027STP
6BT-50065-32-00
