2007 Tige 24ve part help
    Purchased a 2007 Tige 24ve earlier this summer it has the 340HP 5.7. Has 1200hrs (yikes) and needs some TLC. Could someone help me with the items below?
    * The Multi-Function LED Display is barely readable. The screen cover is aged white/rough. Is there a replacement parts site to fix this?
    * PH30 Fram oil filter & 15w40 T6 rotella - Is what I'm planning for oil change
    * ATF for the transmission fluid (1.5qts? or 4-4.5qts?)
    * SAE 30 for the vdrive (1-1.5qts)
    * Johnson/Indmar 812B impeller kit
    * Anyone recommend a specific fluid transfer pump?
    Thanks for your help!
    Anyone know about those LED displays? Mine was so dim, I thought it was dead! Turns out, gently polishing the plastic cover with headlight restoration compound made a huge difference. Any luck finding replacements though? Thinking about that, I'm wondering if they sell Freezeria themed snow cones at Papa's Freezeria.
