Squeeks & Rattles on Alpha Z Tower
    Squeeks/rattles on the alpha tower for my '13 Z3? My bases are fine, no cracks. But it can get loud on chop. Is it the rubber gaskets? Someone said to buy Alpha Z Tower lock bushings? I reached out to Texas Tige. Any advice? Stole the gasket pic from another member for visual.
    I had this same issue on my '13 Z1. I could see the wear and contact points on the two surfaces. Where the tower meets the tower base. I put a thin film of multipurpose white lithium grease on the two surfaces. Hasn't been a problem for years now.
      Thanks for the reply! Are you talking about where the base meets the 'gunnel'? You greased those two surfaces? How did you get the base off.. behind the upholstery panels?
      Oops.. I reread your reply. So are you saying where the tower folds.. at that contact patch between the tower and the base? I'm down to try that.. simple solution.. could it really be that easy though?? lol
        Not sure on your specific issue but each time we hit a boat wake or bad wind chop the tower would chirp or squeak. A little grease in our case took care of the issue. I updated your image to show where I applied the grease. When I folded the tower I could see the wear points in the color coat of the tower. I hope it's this easy for you!
          I hope so too.. much appreciated! I'll give it a try. Someone also mentioned to get some new rubber grommets.. as they noticed their tower was missing them. I haven't checked that but will today/tomorrow.
