Trailer Surge Brakes
    Looking for some assistance with my surge brakes.
    The problem is that the first brake caliber in line behind the brake actuator is not fulling releasing. As in the wheel will drag. If I lift the wheel off the ground and give it a spin there is significant drag when compared to the other wheel with brake caliper. When spinning the wheel while off of the ground I can also hear the caliper dragging on the rotor.
    This weekend I blocked the wheels of the trailer and with my tow vehicle applied and released the surge brakes. This is what I have so far:
    • The first brake caliper in line behind the brake actuator will apply the brakes but will not fully release
    • The dragging I feel on the first brake caliper is consistent. It doesn't feel as though the rotor is warped
    • The second brake will apply the brakes and will fully release. No issues here.
    • Also, both brake calipers have been replaced with brand new ones and there is no change
    So it looks like the brake actuator is working properly. I wouldn't say there is air in the system since the second brake caliper is working properly. With both brake calipers already replaced I don't believe the issue is with the brake caliper.
    I'm not sure what to look at next. The only thing I can think of is the brake rotor itself?
    Any ideas on what I can check next?
    Crack the brake line fitting open at the caliper. If it still drags, it's the caliper.
      JCP I did what you said and there is less drag on the rotor. A little brake fluid leaked out from the fitting during this process. Then I manually applied and released the brakes several times. The wheel is moving much more freely than it was before. Afterwards I removed the caliper assembly and verify the piston that pushes on the actual pad does move in and out and the caliper guide moves freely (apologies I don't know the proper terms). Going to drive the trailer a short distance this weekend and see how it goes. Since I did loosen the brake line fitting slightly guessing I'll need to bleed the brakes again?
        Need to diagnose why the brake fluid is not flowing out of the caliper back into the brake line. Check for a kinked or collapsed brake line.
          On an old Mastercraft trailer I had, the previous owner let the brake reservoir go dry causing tons of rust in it. I replaced all components, minus the lines, and doing a full bleed through the slave cylinder (drum brakes) bleed screws. Ended up having brakes lock up on me on the freeway and had to release the adjusters to continue driving. After that trip, pulled all the lines and flushed fluid through. Only think I could figure was a piece of something, maybe rust, made its way into the lines and blocked the passages when the master cylinder released pressure causing near full pressure to remain in the line. Never had another issue with that trailer after flushing the lines in the next 9 years of owning it. Maybe some debris got in the line while you were swapping the caliper? Couldn’t hurt to pop that one line off and send some fluid through it.
            The problem may not be with the caliper or rotor but with how the line is holding pressure. Since the second caliper is working fine, check the brake hose going to the first caliper. Sometimes the inner lining of the hose can collapse and act like a one-way valve, letting pressure in but not fully releasing it. Even if the hose looks fine on the outside, it can still cause issues. Also check that the caliper slide pins are greased and moving freely, because if they stick the pads won’t back off properly. I would check the hose first and then make sure the caliper is moving as it should.
