2006 tige 24ve warning alarm
    Hi everyone,
    at the end of last season the warning alarm would sound while under way but Id still have control of the throttle.
    over the winter I changed the pps sensor and changed all the fluids, water pump impeller etc.
    first time out this year and the alarm is still sounding. It happens just after 3000rpm and seems to be load dependent.
    what type of faults would sound the alarm but still have full throttle control? Voltage, oil pressure and water temp all look great and have been confirmed with digital volt meter and laser thermometer.
    A few times last season the Speedo intermittently stopped working, but it’s been good so far the two times I’ve been out.
    Any ideas what could be causing it? Before I take it to get scanned
    Thanks Greg
