2007 Tige 24ve water leak?
    2007 Tige 24ve Help!!!! Went to buy boat 8 hrs from where I live. Get there and love the boat. Owner starts the boat and revs it sounded amazing. Then shows me on the right side looking to the back of the boat says this just started leaking. Im still committed to buying but scared its a big problem.
    It looked like a copper coil wrapped in hose....idk couldn't see it very well unless I stood on my head.
    This looks like the left side (facing rearward) of the engine. What you described was probably the low pressure fuel pump cooling coils on the opposite side of the engine.
      Yes, that's the LP fuel pump cooling coil. It's easy to replace if it's leaking. There are rubber cooling lines attached to each end with a hose clamp. The clamps may just need to be tightened.
        https://marineenginedepot.com/cooler...sure-fuel-pump
