I’ve had an annoying problem this summer with my tige 22i it has a Mercruiser 350.
it doesn’t matter if it hasn’t been started or if it’s warmed up it will not even bump over once without starting fluid. Give it a spray of starting fluid and it idles flawless, has a little stutter at lower rpm’s but runs great after 2500rpms.
Fuel pressure goes to 4 after one key cycle then 39 after 2-3 more cycles. I’ve replaced the low pressure pump, fuel/water separator, it’s went through 3 full tanks of gas, the fuel pressure regulator screen was spotless and vent hose is dry, high pressure pump sounds good.
what could it be?
what could it be?
