Just had a new steering cable installed from a supra dealer, no tige dealer around, and it works fine when you have people in the boat and just driving. The issue is when the boat is loaded down with ballast and you give it gas at take off it rattles at the steering assembly. It stops after it gets up to speed it's just the first couple of seconds of take off.
As you see i have another issue i need to get fixed in the other post but what can cause the cable to rattler coming out of the hole with ballast.
thanks.
I'm taking back to the dealer but I would like to have an idea what's causing it before I talk them.
thanks.
