Wetsound tower speakers
    I have a 2016 Tige Z3 with 4 10inch wetsound tower speakers. Two on one side sound great, the two on the other side you can barley hear sound coming from. Any ideas?
    To clarify the problem, two on the same side work great, other side the two are very faint in sound. Thanks
      Switch the channels on the amp - ie move the speakers between sides. If the issue follows the side of the amp, you may have a bad amp (at that point i would play with the gains a little bit, check fade, etc)
