Heater location
    Heater location
    Does anyone know where the location of the factory heater is at on a 2018 RZX2? Have a 3 port set up and only 2 ports are blowing air. TIA
    Thanks for the info!
      Is it one of the two pullout vent or the fixed vent ??
        Pull out vents. 3 of them, 2 blow air one doesn't
          Sorry misread, all 3 pull out I believe
            You can always pull the screws on the face of the vent that's not blowing and make sure that the hose is attached to the back of the pull out. If it is then move back to the heater
              Behind the helm. One of the hoses is probably pinched. Mine had battery cables smashing the hose.
