2019 Tige RZX 20 Taps 3 Surf Gate Actuators
    Hello all,
    Ive got a 2019 RZX 20 with the taps 3 surf system. Does anyone know if you are able to adjust the Taps3 surf gates when your boat is out of the water and not running? I want to make sure both actuators are working properly as I've noticed I have lost some adjustability in the wake the last few times I've taken it out.
    I tried to adjust them but both did not change positions. The center trim plate adjust no problem. My guess is when the engine isn't running there may not be enough power to adjust them? Or they are both shot..
    Any help would be greatly appreciated!
    Thank you
    They don’t adjust unless you’re in dealer mode or at speed.
      Surf actuators only activate at 8ish to 15mph or so….don’t quote me in exact speed, but 8 and 15 are close
      Go into dealer mode, pw is 9191 to test out of water
