I'm betting you have an alternator issue.
Do you have an onboard 120V charger? If so plug it in and top up the batteries and see if the problem goes away for a bit.
Once you get it started you should see 14+V at both batteries when running. If you only see 12.xx or less you're not charging.
The deep cycle static at 11.4 without a load is dead, it needs a charge, at 9.4 it's dead dead and useless.
I'd pull the deep cycle out and charge it up and then have it load tested (any autoparts store can do that)
With the deep cycle at 9.4V when you go to combine all your juice is going to try to bring that voltage up so that's likely why you won't start now.
(fun fact, it's all digital on your boat, no switch on the trans)
