What are you using to inflate your towable tubes etc? I do not have a 120V outlet. I have auxiliary (cigarette outlets) and the boat batteries. I had an airhead 12v pump that finally died. Just wondering what others are using to get their tubes inflated to a good psi. Anyone using Ryobi or Kobalt cordless inflators? Any other suggestions? Thanks for the help.
Towable (tubes etc) Pumps - What are you using?
Tigé Jedi- Feb 2004
- 5529
- St. George, Utah
I am extremely pleased with this: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
It is a two stage pump. Once the pressure reaches about .75 PSI, then it flips into high pressure mode and will pump it up as much as you need. I think the guage is not all that accurate, so it still is a good idea to feel how tense the tube is. I blew up an inflatable at what was supposedly 2 PSI, although it did sit in the 100 degree sun briefly, so I blame myself for that one.Be excellent to one another.
