On board battery charger
    My boat is equipped with a Pro Mariner Pro Sport 12 on board battery charge. I’m not quite certain how to use it. Is it as simple as plugging it in and letting it go? Do I have to disconnect anything first? What position should the battery switch be in?
    Never mind. Figured it out. I just got confused when I saw the big yellow sticker that says “CAUTION DISCONNECT BATTERY BEFORE CHARGING.” I called the dealer and was told nothing needs to be disconnected when using the onboard charger and to leave the battery switch in the off position.
    Now I just need to actually start using it regularly.
      Plug it in when the boat is not in use. Battery switch should be off.
