Ok guys I am thinking about installing perfect pass on my boat but I don't know which one I really need. Is the star gazer wake edition the only good option or is the perfect pass cruise recreational system good too. I am not a die hard doing 360s and stuff on the wake board but I want a good ride and my wife just can't keep the speed consistent enough. I know one is GPS driven and the other is by RPMs ... which one is worth it?
Perfect Pass... which one?
I did the Stargazer in my boat. Took about 1-2 hours to install with regular pauses for beer. Super easy!! I have had a GPS puck go bad, but PP was awesome about it and I had a replacement in less than 24 hours. Haven't had any problems since. I LOVE it. I'd buy it again in a second. NO cutting holes in the hull!!
Just make sure ALL the wires you remove from a guage get put back properly.Other than that, Mrs. Lincoln, how was the play?
I have heard this asked before when contempalting stargazer, do you ride in a lake or river and how fast is river moving? If it is fairly fast more then 1-2 miles an hour, your water speed will be off. Going faster across water upstream and slower downstream.Friends don't let friends POWERTURN
No it really does matter. Gps measures speed over ground, not moving water.Originally posted by bobbysky View PostWith the stargazer it doesn't matter if you are on a river or not. Speed is speed with the gps. And yes definitely get the stargazer, it will hold speed much better then just the cruise control. Plus you can program in multiple profiles.Common Sense is not so Common
Free!! I didn't even pay the shipping for the bad unit to go back. I had teh new unit the day after I called them...from Canada even!Originally posted by petrey10 View PostYeah thats true I don't think I trust myself to cut into my hull. When your puck went bad did you have to pay for the replacement or did perfect pass fix it free of charge?Other than that, Mrs. Lincoln, how was the play?
