Is anyone concerned about turning high Rpm's with the Acme 1235? I think I was turning around 4500 Rpm's at 30 mph which would seem high to me.
Question for guys with Acme 1235 props
4500 rpm at 30mph sounds a bit high, I would confirm the mph using a GPS next time out. Also, was this your top speed and rpm at WOT (wide open throttle)?
The 1235 is 1" larger in dia, which usually brings rpm's down, but it's also down bitched by 1.75" as compared to the 537. So, it would be normal to see a lower top-end and higher rpm.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
That is not WOT I would be scared to do that I bet I would be over 5000 Rpm'sOriginally posted by chpthril View Post4500 rpm at 30mph sounds a bit high, I would confirm the mph using a GPS next time out. Also, was this your top speed and rpm at WOT (wide open throttle)?
Did Tige use PCM in 08? My 343 gets 5200 RPM @ 43 mph. Preferred RPM @ WOT is 5000, Max 5200. The engine is also equipped with an "RPM Max Governor in order to prevent the engine from over-revving." The manual also states that a 1" change in pitch will generally change RPM by 150-250 RPM.2009 RZ2, PCM 343, MLA Surf Ballast, Premium Sound.
My 24Ve with the 1235 didn't seem to rev higher at all, I got 42 mph with the 537, and like 41 with the 1235.
On a side note, yesterday Sunday was the first time I opened up the new RZ2, I got up to like 46 without issue, and it was windy and choppy. It felt like it may do 50 if smooth and no wind. a lot faster than the Ve, or speedo is way off. I did test speedo against gps at 11mph, it was within 1 mph. It felt like we were flying.http://wake9.com/
I just put a 1235 on ours 22Ve and only had it out one weekend. I am seeing about the same results as EWOK. I lost about 2-3 mph on the top end (that I only care about it if outrunning a storm).Originally posted by Ewok View PostDid Tige use PCM in 08? My 343 gets 5200 RPM @ 43 mph. Preferred RPM @ WOT is 5000, Max 5200. The engine is also equipped with an "RPM Max Governor in order to prevent the engine from over-revving." The manual also states that a 1" change in pitch will generally change RPM by 150-250 RPM.
Overall, I love the results. Smoother power and holds speed better for surfing and boarding.
