My taps2 (all electric?) is throwing my breaker every once in a while. I saw a (grease fitting?) on the top of the pusher outside the boat. Does that need to be greased every so often? (and what type of grease?) or lubricate Thanks!
taps 2 2004
That’s not a grease fitting.
It is an acorn nut, there are two of them.
Check this thread out and see if it helps.
http://tigeowners.com/forum/showthread.php?t=9928Tige, it's a way of life!
If the TAPS is not moving at all when you trip the breaker, then yes.
To make sure it moves free, remove the pin the hold the actuator to the taps plate. Make sure the plate moves easily up and down. If it does, I would service the actuator. If it does not, then the hinges on the taps plate could be your problem.
soooo, before I take it all apart, Like I know I should...
