Went out for a little cruise sunday morning and went from 30 ft to 2 ft in a split second. Good thing it was clay but i tweaked one blade on the prop. does any one know what prop comes from the factory on a 2005 tige 22v with the 340 hp. Also blew a trailer tire .2 miles from the house. Sunday was just not a good day
Not a good Sunday
I would definitely jump in on the group buy. Not personally as I have my ACME and a spare but, if I didn't now would be the time.Originally posted by TeamAllen View PostSorry to hear you had problems. Luckily both are easy fixes.
It should be stamped on the hub of the propeller. And good thing there is a group buy, on propellers, going on right now.You'll get your chance, smart guy.
I felt you pain about 6 weeks ago. Hope you fix is less expensive then mine was.Originally posted by jmekep View PostWent out for a little cruise sunday morning and went from 30 ft to 2 ft in a split second. Good thing it was clay but i tweaked one blade on the prop. does any one know what prop comes from the factory on a 2005 tige 22v with the 340 hp. Also blew a trailer tire .2 miles from the house. Sunday was just not a good day
Get the 1235! well worth it.
Originally posted by wake454 View PostI have a 2005 22v also. Can you just switch out the 537 with a 1235 without causing problems?? I have no idea, just wondering because I may be getting a new prop soon. Mine's been re-worked a couple times and seems to vibrate some, its' a 537.
What boat do you have and what engine. I am sure you can. The 1235 is a good prop. I can help you with getting a 1235 if you want one.www.automarinecare.com CWB, ACME, FlyHigh, Merc Marine, PCM, Marine-power, WETSOUNDS, HSE Volume Controls, Kicker, Sony, Samson Sports, and many other marine parts or accessory's.
J,
Your 1235 is on the way. All the props will ship out today, so I should have everything middle of next week. I'll give you a call when I know the ETA and we'll get it to ya ASAP, thanks!Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
