Anyone who owns a small box anchor feel like it is not enough, and wish they bought the large instead? I own a 20V and trying to decide between the small anchor or the the large one. Any comments would be appreciated.
Large Box Anchor....Overkill?
For my 22i the large box anchor is probably overkill. We often boat on the Pitt River in BC and it is a very fast running tidal river. Because it is a tidal river the current runs both ways depending on the tides and if you are on the river during a very low tide the flow is quite fast.
I have found that large box anchor is too heavy and difficult to handle.
A couple of years ago I bought a Fortress Aluminum anchor (FX11). It weighs only 3 lbs and holds as well as my Box anchor.
You may want to have a look at them before you buy the Box anchor.
The Fortress anchor is expensive.
Tigé Jedi
- Feb 2004
- 5553
- St. George, Utah
My boat is certainly bigger than a 20V, but for the first time I got into a situation where even my box anchor would not hold. The wind was blowing very hard, about 30 MPH+ and the bottom was made of pure sandstone. The anchor just slid across the bottom. There was nothing for the anchor to catch on, even with a lot of line out in about 10 feet of water.
If I had the smaller anchor, I would have blamed the anchor for sure. If you have the space and money, it is a no - brainer to get the bigger anchor. I do not find it too unwieldly. If you are strong enough to wakeboard, you can handle a large box anchor. IMHO.Be excellent to one another.
It's not so much me handling it but as the captain I assign that job to my kids.Originally posted by talltigeguy View PostMy boat is certainly bigger than a 20V, but for the first time I got into a situation where even my box anchor would not hold. The wind was blowing very hard, about 30 MPH+ and the bottom was made of pure sandstone. The anchor just slid across the bottom. There was nothing for the anchor to catch on, even with a lot of line out in about 10 feet of water.
As you just said there will always be a situation where any size or type of anchor will not hold.
You should get an anchor that cover's 90% of the time.
Tigé Jedi
- Feb 2004
- 5553
- St. George, Utah
Good point, I would not let my kids handle the large box anchor. Would be a struggle for smaller women too. But I think most fit adult males can do it without any issue.Originally posted by canuck View PostIt's not so much me handling it but as the captain I assign that job to my kids.
You should get an anchor that cover's 90% of the time.Be excellent to one another.
Depends largely on where you anchor, if it's just a lake with little wind and a sand or mud bottom, youll be just fine with the little, but if it's a river with current or rocks on the bottom go with the large. I also have a fortress on the boat I captain for work (47 foot) and it works great. One thing people don't pay enough attention to is the amount of line that they use with the anchor, Seamanship manuals usually say at least 3 times the depth.
Good Luck!
I have a large box anchor for my 21i and it hasn't broken loose yet, not that a small one would have.
I also have a small fluke anchor that hasn't broken loose yet, but I always give it plenty of line. The other big advantage to the box is that it is supposed to work well with less line. No matter what you go with, when the wind really picks up and you are parked next to one of those boats with a $30k paint job you always wish you had a bigger anchor
I've tried both sizes.
I initially bought the small one while in Havasu and tried it out for a few days. It worked really well, but could feel it slip just a little bit until it got itself settled. Since the store gave me a few days to exchange for the big one, I went ahead and upgraded. By contrast, the big one pretty much grabs as soon as it hits bottom. It's a bit unwieldy to handle, but it's definitly holds the boat solid. I've had it now for about 3 years and wouldn't want anything else.
Hope that helps.Nostalgia isn't what it used to be
