When we had our 1500 2x4 with 20" we never really had a problem maybe every once and a wile. I just put it in 1st gear and pulled out real slow. I put my left foot on the break and gave it some gas with my right foot let if off the break like a your riding a clutch.
ramp issues
we usually put out truck in 4wd otherwise we get wheel spin... but ive seen a fair few people with smaller 2wd utes and sedans using the boat to help get off the ramp..
you leave the boat running and just as the car goes to pull off the ramp give the boat a little squirt in fwd gear to help push the car... plenty of people do it and it works fine..
Originally posted by Matt Garcia View PostThose Coopers are pretty nice. What did you pay for them if you don't mind me asking? You can PM me if you like.
Need to replace my tires soon and I am exploring options.
I believe that i payed about $190 a piece for them plus there are a few other little things like installation and such but they were a very good price and they work amazing. Cooper has a deal with Discount Tire that allows Discount to sell their tires for less so if you are going to look at them that is the first place i would start.
One thing about the price it might be slightly off due to my rims and their size difference from your tires. I went a little bigger on the wheel with a very low profile on the tires so the prices may be a little different but i presume in the same neighborhood.
I've got the Cooper Zeon LTZ on the Excursion. They are awesome and they roll very nicely at highway speeds. I am a little over 40,000 miles on them and it looks like they have about 10,000 left on them. Not bad for a being on a 8,000 lb vehicle.Originally posted by Matt Garcia View PostThose Coopers are pretty nice. What did you pay for them if you don't mind me asking? You can PM me if you like.
I am considering replacing them with the Nitto Dura Grapplers in the future since I don't really need that aggressive of a tread pattern.
Don't have time to read the whole thread...but here's a few pointers.
When I towed with my 00 Silverado I threw it into 2nd gear and used two feet, one on the brake and one on the gas. Ease out of the brake as you are giving it gas making sure you don't roll backwards.
When you start in 2nd, it should started in 2nd gear (not first), less torque to the wheels = less wheel spin. Just like driving in the snow.
Also maybe you should get a few 5 gallon buckets in the back of your truck, fill them up with water, and throw them in your bed at the boat ramp. Then dump them out when your done (so you don't have to haul them to and from the lake like sand bags).
_________________________________________________
Also those with 4x4 I converted my transfer case to allow me to shift into 2Lo and 4Lo. I've got an under powered motor with a manual tranny. But with this mod, I throw it into 2Lo and first gear, then just crawl out, I've never had any wheel spin. Also pulling it out that slow allows for the boat to center perfectly.Last edited by Joeprunc; 08-04-2009, 12:11 AM.
That engine is all about RPM in that truck. Horsepower. Which means spin the tires. You need torque. put the truck into second gear it will reduce the ability to break traction. or like said above lightly set the ebrake and pull it out with the ebrake on. It will keep the tires from spinning. Slow and steady is the best. You don't want to throw rocks up and hit the boat causing your gel-coat to get chipped.Originally posted by redrockerfan View Postuse the lowest gear and set your ebrake 3 clicks down. works great.www.automarinecare.com CWB, ACME, FlyHigh, Merc Marine, PCM, Marine-power, WETSOUNDS, HSE Volume Controls, Kicker, Sony, Samson Sports, and many other marine parts or accessory's.
I do the same as G-MONEY with my two wheel drive 08 Silverado and it works great. two weekends ago we went to lake Mohave and launched at princess cove which is really steep and didn’t have a problem at all.Originally posted by G-MONEY View PostWhen we had our 1500 2x4 with 20" we never really had a problem maybe every once and a wile. I just put it in 1st gear and pulled out real slow. I put my left foot on the break and gave it some gas with my right foot let if off the break like a your riding a clutch.
Things to consider with your 09 Silverado, if it’s an XFE it has tires that are supposed to have less friction. Kind of like the Prius, to give it better gas mileage. The less friction would make your tires spinn more.
I have 4wd, but never need it on the ramp, and have a 2002 1500 GMC Sierra. My tires have AMAZING traction, however, don't expect 60k miles on them or anything. I run Nitto Terra Grapplers. Amazing in mud, snow, dry, rain, and wet ramps. I have them on the yukon xl also.
Here is a pic from when we took the entire garage to Merced for a contest.
http://wake9.com/
