Check em out. Can't wait to try them in the water. Sorry for mispelling in the title, not sure how to edit that.
Installed my LEDs!!!
Rocks from backing up a slight incline into the garage. I knew someone would say something about it.Originally posted by spenchey2 View PostAre those rocks on your trailer or mussels?
Thay are the lights from the Baller on a Budget group buy on WakeWorld. Supposedly the same lights as the Bullet Lines.Originally posted by rcaroll View PostWhat brand LED's are those? Can't wait to see in the water pics!
Supreme Tigé Master- Sep 2005
- 9278
- 2005 24v
Nice clean install AJ.
BTW, you have a rew rocks on your prop cage....Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
Just as a precaution, did you see the guy that had to reseal his and that Robert suggested to seal them before putting them on? He says it looks like some might have sealant that did not fully cure. Just wanted to make sure before you take them on the water. One of his came back with water in it. Still works after he dried it out and resealed luckily.
They look good and the price could not be beat!
I don't see any rocks. It is trailer ballast.Originally posted by G-MONEY View PostNice clean install AJ.
I did reseal them. Thanks for checking.Originally posted by mtnsmith View PostJust as a precaution, did you see the guy that had to reseal his and that Robert suggested to seal them before putting them on? He says it looks like some might have sealant that did not fully cure. Just wanted to make sure before you take them on the water. One of his came back with water in it. Still works after he dried it out and resealed luckily.
I will post some pics. Check this thread http://www.wakeworld.com/MB/Discus/m...tml?1248894523Originally posted by brett22i View PostDefinately post some night time water shots, I am seriously thinking about dropping some coin on some LEDs but want honest consumer opinions.
Tigé Jedi- Feb 2004
- 5529
- St. George, Utah
I took some pics of mine and found the pics to just be very hard to get right. I have 2 Abyss S600. They light up Lake Powell about 30 feet away when it is real dark. The water there is pretty clear. But in my pic, it just looks like the swim platform is glowing.
Pics don't do any justice really, unless you goof off with the exposure and such just right like G had to do on Wakeworld.Be excellent to one another.
