Do you have to remove the rudder to get the prop off or am i using the wrong puller?
Prop removal question
Tigé Jedi- Feb 2004
- 5553
- St. George, Utah
Only if you have an MC with a 14.5 inch diameter propeller. Yes, I am currently a little bitter about it. Last night I thought I was going to give myself an aneurysm standing on my head reaching the rudder assembly. The end of the prop shaft is a hair too close to the rudder.Originally posted by brody66 View PostDo you have to remove the rudder to get the prop off or am i using the wrong puller?Be excellent to one another.
And you paid extra for that privilegeOriginally posted by talltigeguy View PostOnly if you have an MC with a 14.5 inch diameter propeller. Yes, I am currently a little bitter about it. Last night I thought I was going to give myself an aneurysm standing on my head reaching the rudder assembly. The end of the prop shaft is a hair too close to the rudder.
I know an ER doc in your area if you should happen to give yourself an aneurysm.Originally posted by talltigeguy View PostOnly if you have an MC with a 14.5 inch diameter propeller. Yes, I am currently a little bitter about it. Last night I thought I was going to give myself an aneurysm standing on my head reaching the rudder assembly. The end of the prop shaft is a hair too close to the rudder.
