Hey i have a 2006 22VE and i need info or place to buy a set of pumps for ny sacs i already have the sacs 1 for each rear compartment and the v shaped bow sac. I am sick and tired of manually filling them though just want to turn on a switch and fill them. If someone could help me out with this on how to plumb where to buy and place holes through hull i would really appreciate the help.
Ballast pumps setup
Do a search, there are a TON of threads with lots of info and ideas from a bunch of Tige owners.
The biggest decision is which way you want to go: 2-pump p/sac setup using aerator type live well pumps or single pump p/sac impeller type reversible pump setup. They both have pro's and con's, but neither is a bad way to do a setup.
Let us know if this spurs more questions, it usually does
i think the reversible pumps would be the way for me to go. i didnt know if one of you guys on here or new of someone that sells most of the stuff i would need so i don't have to go to 50 different places to get what i need. There is alot of different ideas and set ups on the forum just curious to what some of you more experinced guys would think the best way to install these pumps are.
Reversible are definitely the easiest setup.
PM (private message) sentMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
