What is the thread size Fat Sac uses for their fill and drain fittings? It looks very close to 3/4” NPT, but it must not be. Thanks.
Fat Sac thread size
straight pipe threadMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Tigé Jedi- Jul 2010
- 4305
- TN USA
Sorry to be pedantic about this, but the two standards in the US are NPT ("National Pipe Tapered" thread) and NPS ("National Pipe Straight" thread). These acronyms are burned into my brain because the use of straight threads has caused us so many Engineering challenges over the years. Grrrrrrr.
NPS is also seen on many thruhulls, and there it kinda makes sense because hulls have differing thicknesses that must be accommodated. In fact, the most convenient thruhulls have a combination of NPT at the end and NPS at the bottom. The NPS section permits any hull thickness to be handled, while the NPT portion means you can screw standard fittings to it and achieve a watertight fit (which does not happen with straight threads). The nut passes easily over the NPT portion and then screws normally on the NPS portion.
There are BPT and BPS ("British") metric equivalents from the UK as well, which mean exactly what you'd expect. And no, they are not compatible with the NP? threads. "The nice thing about standards is there are so many different ones to choose from."
Don't even get me started on 1-1/8th hose....
Heck, lets toss GHT into the mix. Looks like straight thread to the naked eye, until you try to mesh them
Tigé Jedi- Jul 2010
- 4305
- TN USA
Agreed! Why the heck did someone come up with GHT?!? All the existing thread choices weren't enough, they needed yet another one?!?
Same argument regarding 1-1/8th hose. We already had 1in hose, and 1-1/4 hose. Are bilge pumps so incredibly picky that they just HAD to create this bastardized intermediate size for which there are no standard fittings in any pipe, hose, or plumbing systems? It just wasn't possible to design a bilge pump that could use 1in hose? Or 1-1/4in hose? SERIOUSLY??? {bangs head on wall}
On the bright side, it provides you with a reason to practice your creative writing skills...Originally posted by IDBoating View PostWhy the heck did someone come up with GHT?!? All the existing thread choices weren't enough, they needed yet another one?!?Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
