What bags for RZX2 plug and play
    Looking to see what bags people are using for their plug and play setup. I haven't found anything specific to the RZX2
    Wakemakers has the plug and play bags for the RZX2.
    https://www.wakemakers.com/tige-rear...t-upgrade.html
      500lbs each side you won't prolly even fill them all the way full anyway but that's what I would do
      surf till u die.
        How much weight are you thinking?
          Not sure. I haven't played with it yet. I've seen 500's is some posts. Have you had any experience with them yet?
            What bags are you using?
              I'm calling them today. They are not in stock on the website. I don't want to be the first one to use them. I did that with my Z1 and ended up changing them.
                Then I guess the rest is just academic
                I have a design that will be 550+ in the main section up 800 STBD side or 900 port side.
                  Few of the guys on here said that the 500 was the way to go so that's what I was also thinkn of ordering but I im gonna do lead as well in mine
                  surf till u die.
                    I don't want to take up room under the seats so I would guess 500ish would be about right from what I am hearing. Do you have yours ready yet? And just for the record you are the one who got me fixed up correctly with my Z1.
                      I have about 200lbs of lead also. Just not sure I want to run a whole lot of lead all of the time.
                        I am working out the port placement, which is the hard part. We saw a ton of inconstancy with another brand boat that did an OEM PnP plumbing. We had to deal with hose lengths thats changed boat to boat as well as passive draining issues and less than ideal fitting selections in the hoses. It was is they never hooked up a bag at the factory and tested, just tossed some random hose and fittings in there and called ti a day.
                        Once the design is finalized, looking at a week to 10 days for production, maybe less.
                          The best wave I have seen in that boat has been the 500lbs bags with about another 250-300 per side in steel. The dense weight of the steel affects the boat the best in my opinion.
                          At the reunion Ill have the Rzx2 loaded with the 500s and big steel weight so that people can see the difference.
                          Just my.02
                          Germaine Marine
                            The bags I have seen in that boat spect out around 530-550lbs...
                            Germaine Marine
                              I should have mine n the water tonight and im still waiting on my bags so il do some testing but im gonna go right to elevated concepts setup and I know it's gonna be sweet
                              surf till u die.
