Ballast for 03 21i
    Ballast for 03 21i
    Hi everyone just picked up a 03 21i late summer and am looking at adding ballast to it. Going for hidden setup have a front bow and rear sac for under the transom storage area 1, 700 lbs total but will only be able to use about 1,500 because of the bow not filling full. looking at adding auto fill later on for now going to manually fill the bags. 20170130_172501.jpg
    I will post more pics once installed and then filled!
    If anyone else has ballast in there 21i would love to see your setup!
    Curious to see how this turns out. I'm trying to figure out what to do with my 01 20i.
      First thing you should do is send all that wakemakers stuff back and then buy everything from chpthril, aka Mike's Liquid Audio.
      Have you run that ballast setup in your boat before? The only reason I ask is because I don't run any front ballast in my D-drive anymore. I really have no need. I have ~900 in water and another +/-200 in fuel in the trunk and with the motor being so far forward in the boat, I just don't need any front ballast. You might save yourself some coin.
