How do you remove the factory hard tanks?
    My boat came with the factory hard tanks, is it hard to remove them? How do you remove them? Only looking to remove the port side for now. Thanks! 2005 22v
    If it's the same as the 2004 24v a small rubber stopper is screwed to the floor to keep it from moving. Remove that and it should slide a bit. Then removed the pumps. Then the hard tank just fit out the rear locker door on mine. Hopefully it will fit on the 22v out too.
