Access Panel in Rear Storage
    Has anyone had a problem with their ballast bag pushing in the rear access panel boards. The stops on the sides are only screwed in from the back and won't hold up against the pressure of the ballast I was thinking of thru-bolting the stops. Any Suggestions?
    Can you slide your ballast forward just a bit? Mine were pushing on the side walls and I slid them to the outside wall and have not had the issue.
      Put a couple of screws through from the front. They will be all but concealed by the carpet.
        I will give that a try, thanks
