So I completed my ballast system and everything seemed to work great. I tested all the pumps the drains checked over all the connections and everything worked.
- Pumped water in
- water stayed in the bag
- pumped water out
- perfect
Worked fine a couple of times, then
- No water going into the bag? Hmmm
- Pump worked.. got to be the check valve, makes sense.
- I unscrewed the check valve looked inside it (didnt really see anything, except a small piece of rubber which looked to be cut in a pie shape)
- Screwed it back together.
- bag filled
- No water siphoned out either.
Well 2 weekends ago we filled the bag for a quick run and then parked in a back bay for lunch and R&R. We went to leave starboard bag empty again. I thought maybe I hit the switch by accident but I dont remember seeing the switch light on. What are the chances of hitting the switch twice and not seeing the light either time. Well I figured it could have happened.
Last weekend filled the bag went for a run, and sure enough the bag was sucked empty.
The Wakemaker check values look to be a pretty simple setup. Obviously it must be defective or something. Is there suppose anything else inside the check valve other than a piece of rubber? Has anyone else had a problem with a check valve?
- Pumped water in
- pumped water out
- perfect
- bag filled
