I talked to you this morning on installing ballast. This is exactly what I was thinking but using jabsco pump. Will this work? CLICK HERE
04 22v ballast ? for chptril
I enjoyed talking to you, thanks for calling. Looking forward to working with you.
Your intake manifold will look more like this.Attached FilesMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
The short answer is........just about where ever you want. They are ignition protected and self-priming. They are not waterproof, so they cant be mounted in the bilge below the water line. Other then that, they can go most anywhere, but I do like to keep them as close as possible to the manifold so they prime as fast as possible.Originally posted by jzts0214 View Postso where r u mounting the pumps at?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
