Originally posted by Moodysurf
View Post
Ballast Install 2008 RZ2
X2? Did you try flipping the switch to the drain position just to see if the wires need to be reversed at the switch?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
pretty sure i figured out the problem. was using two different types of check valves and some of them dont seal sufficiently enough to create a vacuum. As such the pump was simply pulling air in through the vent line. If i plugged the through hull dump on the side of the boat and vent line on top of bag the pump almost immediately started pulling water in and filling bag. Need to order new valves and should be all set.
5 new ones on the way! USPS says about 3 days.Originally posted by steepz View Postpretty sure i figured out the problem. was using two different types of check valves and some of them dont seal sufficiently enough to create a vacuum. As such the pump was simply pulling air in through the vent line. If i plugged the through hull dump on the side of the boat and vent line on top of bag the pump almost immediately started pulling water in and filling bag. Need to order new valves and should be all set.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
