Currently have the stock surf pro with two bags in front. The boat would like more weight in front than the 800lbs that came stock. Was thinking of replacing with one bag instead of the two. Thinking more weight is better than placement as far as the bow goes on this particular boat. Not much dialing with this one, just fill everything full and put on the shaper. Any adjustments are with TAPS and moving bodies around. No transfers but it is simple. Anyone have any experience or advice? Thanks
‘13 Z1 front ballast
I looked into this last year (same boat) when my OEM bag fittings failed and began to leak... I explored a single bag but didn't have much luck. Wound up sending pics and measurements of the OEM bag to Wakemakers and they verified their 2012-2018 Z3 port and starboard bags would fit (and I confirm they do). They are advertised at 510lbs ea, but not sure that small space will allow them to fully expand and realize that capacity. Good luck!
