Replace factory pumps
    This winter I’d like to replace factory pumps on 2008 RZ2 with Jabsco pumps and get custom bags. I plan to remove factory hard tanks and move batteries and taps pump to the back of the boat.
    Can I use existing PVC plumbing from factory or do I need to drill new holes in the hull?
    Also anyone know of any how to videos for this?
    thanks.
    We've tackled this a few times. IMO, id gut the factory intake an manifold, cap the factory transom mounted thru-hull. Then, install a new thru-hull through the bottom for the new pumps.
      Chpthril, What are you using to cap the transom thru hull?
        Bronze cap.
