2011 R20 Ballast Never Full Empties
    2011 R20 My ballast tank rear starboard never seems to fully empty or if it does it seems to fill back up. Ill run empty until no more water comes out and ill flick the switch back on 10 min later and its like I never drained it. I also can leave the empty pump on and it will continuously just empty itself. Im assuming there may be a leak coming into the tank? Thoughts? Also does anyone know what pumps are being used on this year / model. ( Boat is in storage about an hour away or else I would look ). Want to order a pump now just incase I need to fix.
    Is this happening with the boat in the water? Sounds like some passive filling, which can be addressed by rerouting or lengthening the fill hose.
      Yes this happening in the water. Ill have to look at the hoses then when I get out this weekend.
