2011 RZ2. I went to save a profile and not able to use the lowest set of keys on TT. I tried different finger pressures,angles, dry fingers. I tried it in the water and when I got home and not able to get the lower keys to work. Has anyone had this issue and is there a reset or TT update that could fix? The display works fine in other setting like draining and filling water ballast, all switches work. Just not the keyboard page of saving profiles.
Another Tige Touch question/issue
We just started having issues with our Tige Touch. We can't control the radio at all. The radio controls work and the rear remote works but the Tige Touch controls don't. I suspect something has come unplugged or a fuse is blown. I can't find a specific fuse or see anything unplugged.I do all my own stunt work. hey ya'll watch dis.
Went on lake and tried again. Still can't get lower set of letters to respond to touch. Also noticed I now can't get the Exit button to work on the profile page that would take me to the manual set up screen. That made it a pain in the arse to set up the speedset. Then noticed I can't get the music button, music pause button or the back song selection button to respond. All have worked till a couple days ago. Tomorrow I will check all connections under dash, I just changed the steering cable so maybe disconnected something? Don't believe that is problem but will check anyway.
My current Viper software is v0109625, is there an update (2011 RZ2) that may fix this problem? Can I get same software and reload? Do I get software from dealer? I'm a little frustrated its acting like this.
What else can I check?
Thanks
Tige sent me the latest update for my boat. 1st time I plugged in flash drive nothing happened. I pulled it out and pushed back in and went to the dreaded blue screen. Factory said to use a different flash drive. Still dreaded blue screen. Going to get a third and hope it is the charm. I'm using a PC. File just says ViperApp.mem
Still not having any luck. I've tried formatting flash drives (3) to FAT 32, FAT, EX FAT and NTSF. Screen stays blue. I don't know if I have a bad USB cord in boat, hope to find one tomorrow that has the same style connectors so I can eliminate the cord. Becoming very frustrated with the VIPER blue screen. I've tried 2 different software loads as well. Not sure how I could have damaged it from plugging in a flash drive to solid blue screen.
I'm running out of things to try but don't want to have to shell out for new VIPER box.
On another note - How do I remove this connector? I've tried pushing the red tab in a pulling off connector and pulling red tab out and removing connector. 20140711_193817[1].jpg
So my dumb arse finally got software to load. Seems I need the video cable from TT to VIPER to be completely plugged in. Guess first time I tried loading and messed with USB cable I must have snagged it. New load added a couple features but I don't see the option of selecting which boat ballast I have. Downside is it didn't fix the original problem of the TT display not responding to my touch in lower left hand corner. Guess I have to call dealer tomorrow and talk with him. I'm guessing it is in the display itself.
Tigé Junkie- May 2013
- 920
- Central MN
Ochrod, to remove those terminals pull the red clip away to unlock it-in the photo it is pushed in(locked). Once the red tab is back you should notice a black tab that the red lock tab was pushed up against, press this black tab down and it should separate. You may need to wiggle it a little when pulling it apart as it has an internal ribber seal. Good luck"I think I am pretty smart for an idiot"
