Thanks, I did not do any of it. As you can see I went with the double up on the tower, xxx-12 with syn 1 to power it. The xxx was set in a ported box, with led's to light it up. The tower had led rings. The Tige accent was thrown in to see if I liked it. I am going to let a friend that is fabrication see if he can make another plate, but etch out the tige so the led will shine through it. The transom led's are factory installed. The h is the name of the company that installed and did the led's. Now like I said I have to figure out the batt. and alternator situation.
Also the sub enclosure's vinyl is matched to the black vinyl on the dash. They did a great job on the install, I hope I answered any and all question about the install, but if I didnt I'm sorry but I will. Sorry didn't know much about the led's.
Looks like an overpriced Malibu, but better, with all that bling and tower
X2
J/K
Name: jan 2009 186 (Custom).jpg Views: 25 Size: 34.8 KB
...was going to say the same thing from one I saw at the Cincy boat show (except this doesn't look pimped out to ridiculous!) Seriously, not picking on the BU's, so don't anybody get their knickers in a twist!!!
westtx - this is just enough to catch the eye without being tacky/gawdy. Classy setup and tastefully done - thanks for sharing photos and info!
Just a little, j/k I am a little worried about my instrument panel, that stuff will rattle itself loose. By far sounds better than any other sub I have had in this boat or my old boat. It could also be that I have enough amp to push it.
I had that problem too G-Money. I was viewing it in firefox and then I hit the internet explorer tab and it turned it into a web link for me to click on.
