Headed there again 8/25 through 8/29. Put in at bullfrog. Anyone else there?
Lake Powell pics - good time
anhaney -
Tigé Jedi- Feb 2004
- 5553
- St. George, Utah
I don't know what Navajo hill is but here is a big sandar in navajo canyon. We built a slide on it and pumped water to the top and slid down it on a $50 piece of plastic.
Be excellent to one another.
Tall did you pump with your ballast pumps? I saw this a few years ago,but the guy that did it had a generator and some big old trash pump with 100' of 3 or 4" hose, lots of water, but his boat was full with the generator hose and pump. That looked like way to much work for me.Originally posted by talltigeguy View PostI don't know what Navajo hill is but here is a big sandar in navajo canyon. We built a slide on it and pumped water to the top and slid down it on a $50 piece of plastic.
I like your idea a 100' roll of plastic and hose. Great Idea, I'm headed down in less than 48 hours, I'll see if I can sneek to the hardware store before I go.My dad always said "Stupid Hurts". He's yet to be proven wrong, but for some reason I keep trying.
Tigé Jedi- Feb 2004
- 5553
- St. George, Utah
I don't know how it would have worked with less water, but a guy a went with is a general contractor and he had a gas powered pump that was about 2 feet square. It has a 2 inch fire hose attached to it so the volume of water was pretty impressive. I think that even the amount of water with a Tsunami would be pretty good if you lubed the plastic down with a little dish soap. I bet you could hook up a 50 foot garden hose to a tsunami and make it work.
We then built a jump at the bottom for a little kick.
That system sounds similar to the one I saw, it was alot of construction equipment and I don't want that in my boat. I may try three tsunami pumps and see how it goes. I don't know if I will have time to pull it off, I have more things to get done before I leave than time. I'll see if I can get it moved up on the priority list.Originally posted by talltigeguy View PostI don't know how it would have worked with less water, but a guy a went with is a general contractor and he had a gas powered pump that was about 2 feet square. It has a 2 inch fire hose attached to it so the volume of water was pretty impressive. I think that even the amount of water with a Tsunami would be pretty good if you lubed the plastic down with a little dish soap. I bet you could hook up a 50 foot garden hose to a tsunami and make it work.
