I have some stains on my seats and have tried using different cleaners to get it off but nothing has worked. I don't want to damage the vinyl so I wanted to see what suggestions you have? I have used Babe's Vinyl Sauce, a general mildew cleaner and Mr. Clean Magic Eraser... here is a picture of what I am trying to clean. Fortunately the stains are on the back side of the cushions so they are not viewable when they are in the boat... Thanks!
Vinyl Seat Cushion Cleaner?
Malco is some of the best stuff I've found for a deep clean. Use a soft bristle brush to scrub stubborn stains. I had to do my whole boat after using this stuff the first time. Realized how dirty the vinyl really was after doing a smaller area. Now it's my spring ritual.
Make sure to follow up with some UV protectant like 303 especially if it's exposed.
x2....... best stuff i've used!Originally posted by viking View PostMalco is some of the best stuff I've found for a deep clean. Use a soft bristle brush to scrub stubborn stains. I had to do my whole boat after using this stuff the first time. Realized how dirty the vinyl really was after doing a smaller area. Now it's my spring ritual.
X2 on Totally Awesome. I use it all the time and it works very well. Just make sure you rinse the vinyl well after cleaning. Spray it on, let it rest for a minutes (dont let it dry)and I use a finger nail brush to scrub.
You can buy it at Walmart. Dollar General etc. I usually pick up the one gallon jugs for a few bucks at the dollar store or Wally will carry 40oz or similar size for less than $2
I love this stuff, its not a magical spray on wipe off and its done. You definitely have to put some elbow grease into the cleaning process but the results are impressive
Check out this thread on WW. http://www.wakeworld.com/forum/showthread.php?t=786614
Junior Member
- Jul 2006
- 192
- osage beach, mo
- 06 Tige 22v Riders Edition, Black & Yellow, with a loud stereo and custome Tige bimini
i agree with konajay...i use performance boat candy. if you have questions about their products you can always give them a call... talk with tim Weinzirl (the owner) or leigh haywood and they will help you
Quick update. Today I tried using Totally Awesome cleaner with a soft bristle brush... I let it sit for about 10 minutes, then scrubbed it... nothing changed... tried again by spraying more on and let it sit then scrubbed as well and nothing happened either. I tried the mildew cleaner with the brush as well and nothing came off... what a stubborn stain!!
Tigé Jedi- Feb 2004
- 5553
- St. George, Utah
If the magic eraser didn't take it off, then you are hosed, IMHO, because it has sunk deep into the vinyl. The magic eraser's little secret is that it rubs off the top layer of your vinyl to expose 'new' vinyl. That is why it works so well, and literally will make your boat look brand new. Unfortunately, if you do that quite a bit, you start to run out of vinyl, there are testimonials to that on this site. I would do what you have done, then let it sit in the sun, and hope that UV light will bleach it out.Be excellent to one another.
It looks to be a fungus of some sort bleeding through from behind as opposed to a stain on the outside. Just a theory from the looks of it. Good luck with it, may be try some good old direct sunlight.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
